? about heads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GONZO, Jun 4, 2001.
  1. GONZO
    GONZO Registered Member
    Feb 20, 2000
    59
    Great Falls MT
    will the aluminum heads from a newer 5.3L chevy fit on my 85 350? if they do how does $300 plus shipping sound?
    <font color=blue>85 k5 Blazer 4x4
    99 Trans am 30th anniversary
    79 Trans am [​IMG]
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    NO THEY WONT.
    New '90 K5 sitting in my driveway !!!
    <A target="_blank" HREF=http://www.tori89k5.coloradok5.com>http://www.tori89k5.coloradok5.com</A>
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i know the vortec heads of a new 350 fit. but you have to machine your block. they cost the same too. i am not sure if they are the same as the 5.3L though. but i have seen it done. the motor performs well too.
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    No.
  5. GONZO
    Feb 20, 2000
    59
    Great Falls MT
    thanks
    how good are the 350 vortec heads? is it a worhtwhile expense?
    79 Trans am [​IMG]
  6. dyeager535
    26,980
    Very good head, with major improvements over most heads, and slight advantage even over the revered "camel hump " heads out of the 60's, commonly called "fuelie" heads as well I've heard lately. (not sure why, since they weren't put on just FI vettes) Do a search for posts on Vortec heads.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  7. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    For vortec heads you do NOT need to machine the block, it's a direct bolt on. They do require a different intake tho. I'm not sure what seventy4blazer seen ,(unless i am totally reading his post wrong) but the 5.3 heads wont go on an early style block. Totally new animal, NOTHING will swap on these 2 motors.
    PURE INSANITY
    86 blazer see it at:<A target="_blank" HREF=http://www.zing.com/album/pictures.html?id=4292792569>http://www.zing.com/album/pictures.html?id=4292792569</A>
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yes, the 5.7L vortec heads do fit. the block need machined and you have to use an intake that matches the vortec heads. call me a liar if you want, i dont give a $h!t
  9. dyeager535
    26,980
    No machining necessary of the block. Friend thought the dowel pins were different, but they are not. Only machining that might be necessary is if you want to risk your heads, and drill them for an earlier style intake. Everything else about them is the same, except lack of heat crossover, which is not opened up. I've got a pair of vortec heads in my garage that are going on my '69 350 block. Guarantee no machining will be necessary.
    Dorian
  10. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Definitely no block machining required to bolt Vortec heads on an older block (ANY gen 1 or gen 2 SBC block for that matter). I have them on my motor (original motor from '72 Blazer), and they bolted right on.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  11. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Easy there 74!!! If you read what I posted I said unless I'm reading you post wrong. I wasnt callin you a liar!!! I know you need the special intake manifold, I HAVE the intake!, on my vortec heads!! I was making reference to the 5.3 heads on the Gen 1 and 2 blocks. Now as far as the machining of the block, that is incorrect. There are too many of us that have those heads on our rides to not have an idea what it takes to install em.
    PURE INSANITY
