??? about mounting stuff on a roll cage
Discussion in 'The Garage' started by 70jimmy, Mar 29, 2006.
  1. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Got some stuff I need to mount on my cage and wondering what is best and why.
    Speakers: they are like 6 X 9 box speakers with typical U shaped mount.. I was thinking they could be riveted by drilling hole in tubing and using a rivet gun to mount. Drilling a hole and tapping it for a bolt to mount the speaker, or drilling a hole all the way thru and running a longer bolt thru both sides.
    Fire Extinguisher: Same methods plus I saw a velcro attached foam holder. Not sure how that would work.
    Let me know what your opinions are. thanks.
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    attaching stuff to a cage is fine... though I wouldn't drill holes in it to do it. Better to weld on some tabs and bolt stuff to them.
    j
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I got these. Bit 'o the bling, but very functional.
  4. 70jimmy
    Mar 3, 2000
    5,962
    252
    Thanks for the replies. Ski girl that is just what I was looking for. Wow does the price add up quick!!! Look like great products.
    anybody got anything else similar in design?????
    Although I don't mind a little bling bling.
  5. Hermy13
    Hermy13 Registered Member
    Aug 27, 2005
    22
    Iowa
    go to your local dirtrack racing store and look at there weight hangers that clamp to the frame
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I use hose clamps for a lot of that type on mounting. Not nearly as fancy, but works as well if not better and a whole lot less spendy.
    Just make some tabs that bolt to what ever and lay flat along the length of the tube. Depending on length & weight one may do it, but it usually needs two.
  8. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    why not just use some u bolts? simmilar to cheap exhaust clamps.. just the u part drill a couple of holes in the speaker box and put a washer on befor each nut? it would only cost like 5 bucks and would work great.
  9. 70jimmy
    Mar 3, 2000
    5,962
    252
    Good idea skid pan I am definately gonna check into that. I could probly even get stainless or chrome for some bling. Just wouldn't feel right to hang a $14.00 speaker with a $40.00 clamp. :doah:
  10. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Thats pretty cool!
  11. Skigirl
    Apr 2, 2001
    2,563
    I'm getting one of those to mount the camera I'll use to film the Aholes "driving" in front of me, which I will upload to a website entitled something like stupidfokingdrivers.com
    I already used one to mount my rear view mirror - it has a 4" monitor embedded in it, and was too big to attach to my existng rear view mirror. So I took off the stock one and used this to mount the new mirror.
    Also going to get some fourtreks stuff to mount sun visors to the roll cage.
