? about rear disc brakes
Discussion in 'The Garage' started by chevystepside, May 16, 2003.
  1. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    was at a junk yard and found 4 cadallac eldorados but they are from 1980-83. are they the same as the 1976-78? cause i dont have anything to compare them with. they have the e-brake built into the caliper. if anyone has run into these and knows if they will work please let me know. /forums/images/graemlins/smile.gif
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I think the spread of the newer ones is not enough for the 8 lug rotors, they should open up with pads to over 1.275"
  3. chevystepside
    Sep 23, 2002
    147
    leadville colo
    the rotors that i'm using are six lug. i'll have to go measure the front rotors on my k5. man i hope that they measure 1.275 or bigger. the bolts that hold the calipers on look real close to the stock dimions as in the spaceing from bolt to bolt. thats for the info /forums/images/graemlins/thumb.gif
  4. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    the calipers from the 76-78 eldorado have 7" mounting screw
    spacing, and use 1.25 wide inch rotor,
    the calipers rom a 79-85 eldorado have 5.50" mounting screw
    spacing, and use 1.00 inch wide rotor,
    hope this answers your question,
  5. dyeager535
    26,979
    No, the 79-85 calipers WILL NOT WORK with the truck front rotors.
    The pin-to-pin spacing is 5" on the newer ones, the calipers are designed for 1" rotors, and the trucks run 1.25" front rotors, which is what the 7" pin-to-pin 76-78 Eldo rear calipers are designed for.
    Don't waste your time, I've got a set of the 79-85's in my garage.
  6. ZK5
    ZK5 1/2 ton status
    Dec 16, 2001
    100
    Meriden, CT
    I just did a disc conversion on my 14bolt. I have a used/rebuilt set of 77 eldorado calipers complete with pads and hardware that I did not use. heres why #1 you have to take the caliper soff the truck to bleed em. #2 They did not open up enough to clear the brand new rotors. #3 you need a special tool to turn the caliper piston. #4 hooking up the ebrake cable was more trouble than it was worth. #5 brake pads were not readily available, I had to order them from the dealer.
    my solution was to use 85 front 3/4ton rotors/calipers/pads/hardware and use a brake lock for a parking brake.
    visit www.brakelock.com (well worth the investment.) PLUS now noone can steal my truck.
    hope this helps.
  7. the cork
    Apr 20, 2003
    128
    mid west,
    well THATS WHAT I GOT FROM MY KIT, from tsm, /forums/images/graemlins/thumb.gif
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yes, that is true and that is a PITA.
    I did not have that problem. I have the older TSM kit and use Ford rotors.
    Somebody else said that too. WHat special tool is needed? I used a socket on the ebrake nut and just turned.
    I thought the same thing too and put it off for a long time. Then this past week I finally just sat down and did it. It is well worth the time. Honestly, even making the little bracket for the ebrake cable wasn't even hard and I'm fairly new at welding and fabbing.
    I got a set at autozone. They were in stock. They are the exact same, as far as I can tell, as the pads for the Dana 44 calipers I had on there before.
    Just wanted to share my experiences.
    -- Mike
  9. ZK5
    ZK5 1/2 ton status
    Dec 16, 2001
    100
    Meriden, CT
    The tool is just a common gm disc brake caliper tool it fit's into the center of the piston and then it has a pin on 1 side the fits into the notch on the edge of piston face. Then you can turn the piston into the caliper. (does the same thing just without removing the ebrake lever). I was going to the same as you did with the cable, But I guess the question is..."are your calipers mounted forward,rearward or topcenter on the axle"? Mine are mounted forward and this would mean having the brake cable go behind the axle and underneath. I would have ripped it off wheelin. even if I mounted them rearward and swapped sides I still could not see having all that cable. I would like to see pics of how you managed to hook yours up if ya got any.
  10. dyeager535
    26,979
    Hey, pretty similar info, especially with me culling that from memory /forums/images/graemlins/smile.gif
  11. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I used to have them mounted up, back when I had the d44 calipers. When I went with the eldos, I had to change the position so that the ebrake caliper would be able to be pulled straight forward. So, the calipers are exactly on the rear, just like the front calipers are.
    As far as brakelines go, I went to the store and bought front brake hoses for a 76 k10. I had to grind a nub off the brakehose connector (easy) but they fit fine and the hoses point directly towards the differential. Then, of course, I just have 3/16" hard line to the center connector.
    I wish I hadn't sold my braided SS brakelines from when I had the 3/4 ton front axle. I could have used them on the rear calipers and I think that would be the best option.
    I'll try to post some pics of the bracket/calipers - PM me in a couple days if I get busy and forget.
    -- Mike
  12. LUBA
    LUBA 1/2 ton status
    Jan 16, 2002
    127
    Bay City, Michigan 48708
    I am doing this conversion right now, and I also am having problems with the eldo calipers fitting chevy 3/4 ton rotors. I could not get the piston far enough in, so I took it apart. Big mistake I tried putting piston back in with a press, but I must have stripped it. Guess I got cores now. As far as the brakes I just bought albany eldo pads with a lifetime warranty for $9.99 at Autozone. These are the cheaper ones the guy there recommended these for wheeling and mud. Did you guys that run this set-up have to turn down your rotors of grind your pads to get them to fit?
  13. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I did not have to grind down the rotor or pads. For a minute I thought I was going to have to, but then I got out a socket and ratchet and turned the nut back of the caliper where the ebrake lever attaches. It opened up just the last little bit. Did you try that?
    I have Ford rotors, but they should be the same thickness as the Chevy ones.
    -- Mike
  14. LUBA
    LUBA 1/2 ton status
    Jan 16, 2002
    127
    Yes, I did and it didn't work. It ended up coming apart. I screwed it up trying to put back together. I will be buying new calipers if they are wide enough!
