? about tire/ suspension upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ben794X4, Feb 11, 2002.
  1. ben794X4
    ben794X4 Registered Member
    Aug 29, 2001
    53
    Boise Idaho
    My old 31,s are worn out and I now can finally justify replacing them. However, I have a limited budget and these are my options; I can either run 33,s and install a locker or a four inch lift kit and 35,s with open diffs then do the locker later. I need as much clearance as I can get (duh) without getting to tippy and I am not afraid to chop my wells which I need to do any how to get rid of some rust. I plan on doing it all eventually but I dont know if a 2 1/2 lift or a 4 inch would be better there are alot of side hill trails with BFR's (big friggin rocks) where I wheel in the Murphy desert. These (BFR's) can pitch you pretty good when you are already side hillin' making for a high pucker factor. All responses are appriciated as are product recomendations.
    Stock 79 4X4
    3 spd granny
    stock 350
    12 bolt open rear
    10 bolt open front
    Subvert the accepted paradigm.
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i would say go with the 4" and 35s. Thats whats on my truck now and after a day with the sawsall it flexs pretty good. also you go up to 6"s with the ORD addaleaves and body lift to fit a good size tire without losing to much balance.
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I agree with sapper, go with the 4" lift &amp; the 35's, you won't regret it. You can allways install a locker later, or weld your rear end now &amp; forget about the locker.
    Just my opinion
    '80 K10 350/350/NP205/14B/10B/4.10/4"Lift/Q78-Buckshots
  4. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    I agree with the 4" 35" combo. See the Driveshaft thread for more info.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74Blazer Topless W/ 35 BFG Muds1" Body Lift W/ Energy Susp. Bushings
  5. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    4" lift and 35s, no question. If you have no probs cutting fenders, you could run all the way up to 39.5s with 4" of lift, so you'd be set in that regard. Lockers are great, but u can always get one later.
    as far as tippy-ness goes, add the spacers on your rear wheels to even out your track width...run wide tires..and ditch your hard top, tail gate, and doors...maybe get a fiberglass hood too. ;) Reducing top-heaviness is always a good thing,
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  6. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I always thought itd be tippy with my 6" and 35's but after driving it seems normal, i want to go even bigger tire wise. The k5's are pretty wide,just ditch the hard top for a soft one.
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 6"susp, 35" BFG Muds, CatCo Cat & Series 40 delta flow 3" tips.
