? about zero rates
Discussion in 'OffRoad Design' started by Ruff_ryda_420, May 28, 2003.
  1. Ruff_ryda_420
    Ruff_ryda_420 Registered Member
    May 22, 2003
    19
    alberta
    i heard everyone on this board talking about these "zero rates" and i had no clue what they were. so i looked into them and was very surprised, it's a great idea. anyways, i'm just starting a mild build of a 78 K5 w/ a D44, 12 bolt, SM465 and a NP205. my plan is to put an S10 body on the frame. the problem is that the S10 firewall won't clear the distributor well and the cab has to be moved back, hence the front wheels won't be centered in the wheel wells. would there be any problem using the zero rates to move the front axle 1.5" back to help center the axle to the wheelwell?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Not in the least bit, they are designed to move the front and/or rear axles forward or backwards 1" to 1.5" /forums/images/graemlins/thumb.gif well worth the money /forums/images/graemlins/thumb.gif
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You can use them to move the axle back, what you may find you need to do is actually leave the axle in the stock location and stretch the fenders to make a bigger opening. We have several customers that have done this swap and that seems to be a good way to make enough room under the hood and in the wheelwell. The stock S10 fenders aren't very big....
  4. Ruff_ryda_420
    May 22, 2003
    19
    alberta
    that is very true, they are small fenders. i'll look into stretching them, it may be a better answer.
