ABS Conversion
Discussion in 'The Garage' started by Rolled, Sep 20, 2006.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Any info out there on adding ABS to my 82 K20?
    I have a 1991 K5 with ABS (I think) and am wondering if it is worth pulling (before it goes to the crusher) and putting in my k20?
    Any advice? I am not really sure how the system even works so I don't know, yet, what parts to pull.
    Its a seperate system from the motor ECM, right?
    I'm pulling the pedal assembly for an auto conversion and thought I may want to add the ABS if its not a hassle...
  2. dremu
    Feb 27, 2000
    15,957
    446
    East of San Francisco
    ACK! NO! BAD! :rolleyes:
    Seriously, it's a pretty miserable ABS. It's rear wheel only, and is famous for failing ... not that it does much. The only truck I ever had with it kept popping codes and it was easier to disconnect it and treat it like a normal system.
    -- A
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yeah, I wouldn't want it. Even my S10 is popping codes, and it doesn't even have ABS! Figure that one out.:crazy:
