ABS for 14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Apr 7, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    In 1990 the Blazers came with rear ABS. So what do I do when I swap in the 14 boltff? Will or can I still have the ABS?
    Same goes for the front swap, is there a sensor or something I can change over from the 10 bolts??
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    You may be out of luck unless you get the axles from a donor vehicle that has ABS. Disconnecting the ABS may not be worth it or more trouble than it is worth. There is a tone ring that should be inside the front hubs and on the axle shaft in the rear that lets the ABS sensor know when lock-up has occured. You can probably order retrofit axles for the rear and you may be able to use the front hubs off you current vehicle (some year models 10 bolts are pretty much the same as a Dana 44 from the knuckle out). Anyone else have any ideas????
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Check with Steve on that one. He had ABS when he swapped in a 14 bolt. Check on the home page and read the articles there but I don't think he had any problem.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails<font color=blue>
    <font color=blue>Wayne<font color=blue>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think that the rear wheel speed sensor is on the driveshaft (or T-case output). If you don't have wires going to the rear axle than you are in the clear. The only other thing that matters is your final drive ratio (gears and tires)
    '71 Blazer CST with alot of rust
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have replaced both front and rear axles and driveshafts and had no problems with my ABS. There are no wires running to the either axle.
