Absolutley Filthy Engine
Discussion in '1982-Present GM Diesel' started by 82diesel, Sep 18, 2003.
  1. 82diesel
    82diesel 1/2 ton status
    Jul 2, 2003
    316
    Stockton, CA
    I was just wondering if it was normal to have a sooty gunk right underneath the air filter case. The top of the manifold is covered with this gunk and my K and N filter is already dirty as heck with only 3000miles.
    It doesnt use oil less than a quart in 3000miles, and no blue smoke. But it puts out alot of white smoke for the first 20mins/10miles. Just cold ?
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Just a wild guess...you have your EGR valve hooked up? Unhook it and plug the line and plug the hole where the line goes into the air filter case. The EGR takes the exhaust and recirculates it to get better mileage, at least thats what I have heard.
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    This "gunk" is from CDR system (similar to PCV on gas engines) allowing oil from crankcase in vapor form settle inside manifold before its drawn into the engine. Nothing you can really do about it since you will always have blowby and the CDR system is necassary to keep a negative pressure in the crankcase.
    EGR has little or nothing to do with it and is there to lower Nox levels, not change mileage in any way.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Exactly.
    Now if you happen to have a lot of blowby then you can just put a breather on the end of the line insted of letting it return to the intake.
    That got my oil conumption down a little an dmade the engine run a little smoother.
