AC add on
Discussion in 'The Garage' started by 27scrappers, Apr 22, 2006.
  1. 27scrappers
    27scrappers Newbie
    Apr 10, 2006
    Tucson, AZ
    Not something that most of you probably have to worry about but...
    I need to add A/C to a '72 Blazer that was not equipped that way from the factory. I've started looking at Vintage Air and Old Air products but could use any guidance/advice you might offer. The truck has mild 350 (20K miles), stock radiator, 4spd. Thanks in advance.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've never had to do it but if I were to try it I'd be looking at smaller cars systems to see if they could be adapted. K5 systems are big and you'd have trouble squeezing it into an early truck I think.
    A set up from a car may be small enough to fit up easily. Then make up some ducting inside. It could be a good time to convert to serpentine too.
    Vintage air etc would be more straight forward but I think they're expensive aren't they?
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I think the aftermarket kits are the way to go.
    IMO you will very likely spent near the same $$$ cobbling together used stuff, paying to have the bad pieces replaced, and get the system charged and retrofitted with modern refrigerant.
