ac and heater problems
Discussion in 'The Garage' started by unick, Feb 21, 2004.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    when i try to use my ac or heater it just blows outside temp air into the K5. Anyone know what it could be? Its an 87 K5
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    So basically if its hot outside or cold outside thats what you get.....sounds like a venting or cable problem. Something isnt opening or closing. Never had the pleasure of taking one apart yet. Air always blows through I've noticed on our trucks while driving. The temp lever is what should open the doors to alow air either over the evaporator (a/c)or over the heater core. Wish I had a real answer for you. /forums/images/graemlins/k5.gif
  3. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    The mode switch is hooked into a vacuum source, I had a vacuum connection come off on the passenger side kind of up under the dash a little, next to the kick panel. It could be that.
    Also the temp lever uses a cable that attaches to the plenum behind the glove box. I had the plastic clip break once so all I had was outside air. Pull your glove box and move the temp selector lever and you should see what I mean. /forums/images/graemlins/thumb.gif
  4. unick
    Aug 16, 2003
    4,286
    Ok well I check the cable and its hooked up and working. Ill have to go check the vacume line later. Its raining outside.
    Nick
