AC/Belt Vibration Problem on a Carbed 86
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AntAZBlaz, Jun 9, 2003.
  1. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    Hey
    First off hello to everyone it’s been a while since I’ve been on the site.
    Here is the background. I have an 86 350 carb from the factory.
    Here is the problem when I turn on the truck on everything runs smooth. When I hit the AC the belt for the compressor starts vibrating up and down hard. When the engine is off I can check the belt for deflection and it only moves about ¼ inch when you press on it hard so I don’t think that it is caused by a lack of tension.
    I have noticed that when the idle is set lower the vibration increases. When I crank up the idle the belt vibration decreases but then I end up dieseling when I turn the truck off.
    So what can I check for to get this problem worked out?
    Thanks for any help.
    King
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    bent compressor shaft?
    this is a good question.
    Grant
  3. Doug M
    Doug M Registered Member
    Nov 8, 2002
    39
    Houston
    Mine does the same thing, I've heard lots of others do it as well. It has ran fine that way for at least 6 years now, no problems.
  4. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    My 1986 Suburban does make a noise, too. Here's the scoop from a post I made on another board a while back...
    "Yeah, a dull moan, right? It's the drive pulley for the compressor. It's "normal" and nothing to worry about. Mine's done it for years now. However, there is a "fix" for it and was posted here a while back. Essentially, it's a matter of swapping out for a heavier pulley.
    Found it!
    In reply to:
    With warm weather just right around the corner, I felt now would be a good time to address this problem. When I got my truck, the A/C system would make a strange moaning and vibrating noise when I used the A/C. I found out there was a TSB addressing this issue. This covers '85-'88 light duty trucks and vans with the R-4 compressor using a regular drive belt. If your truck is experiencing this problem, get p/n 6552402 compressor pulley. It is heavier than the original and it will take care of the noise. Replacing the pulley requires special tools, so when you get the part, I would let Chrevolet or an A/C shop put the part on for you.
    1987 4x4 Shortbox Stepside
    www.picturetrail.com/87BlkStepside "
    Hope this helps...
    Kevin
    /forums/images/graemlins/burb.gif
  5. AntAZBlaz
    273
    Mesa AZ
    thanks for that message, i tried doing a search but i wasnt to successful. i'll try looking up how much that part costs thanks.
  6. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    Sorry to dig this old thread back up but it I've been trying to track this part down and I've found out that it's a GM discontinued p/n and that only 2 dealers in Texas have one! The price on the new pulley is $115 so I'm not sure if it's worth it to fix this annoying noise. Do any of you other guys currently have this same issue?
    Thanks,
    Wes
