AC blower motor
Discussion in 'The Garage' started by tx_sub, Jun 6, 2004.
  1. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    the highest fan speed does not work. the other positions work but not the highest setting. my question is this, is this a sign of the motor going or the switch itself. the other fan speeds don't seem to blow as hard as they used to. is there an easy way to determine which component it the culprit?
    thanks y'all
  2. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    if the motor was going it wouldn't want to work in lower settings. i would say you have a wire/switch/plug problem. time to wip out the volt meter, or start wiggling, pounding and jumping with another wire, the backwoods way /forums/images/graemlins/waytogo.gif.
  3. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Sounds like the switch.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    On some trucks, like mine, even when it is on high, it blows more air on max a/c than it does norm a/c. Enough of difference to feel/hear /forums/images/graemlins/k5.gif
  5. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    I would make sure that the blower motor you have is for a a/c truck. I work on one awhile back the evap would frost over in a hour or so. I rechecked my charge and temps ok, turned out someone had put a regular fan motor on this thing, it didn't move enough are to keep the coil clear.
