AC compressor for an air compressor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mich89k5, Nov 8, 2000.
  1. mich89k5
    mich89k5 Registered Member
    Oct 30, 2000
    40
    Michigan
    I can't remember if it was on this forum or in a magazine that I read, but I'm wondering if it's possible to convert my AC compressor to an onboard air compressor. It would be great if you had any pictures, but written details will work of course. I recently had my AC compressor replaced because the pulley froze up and snapped my belt. The AC never worked when I bought it last Sept. and I'm not really interested in having AC. I hooked up the compressor, but made sure not to hook up the electrical connection to it since it has no refridgerant or oil in it to lubricate. So basically all i'm using it for is for the pulley. I tried to find a dumby pulley, but I was kind of pressed for time since it broke down on the highway 60 miles from home. Anyway, I'm hoping the fact that I haven't filled it with anything might make it easier to convert to an air compressor. Any ideas?
  2. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    Here is a link to instructions on how to do it, pretty easy, I am going to do it eventually when Iget some more money.
    http://www.geocities.com/corey_perez/onboardair.htm
    Vincent Michels
    1978 Blazer
    Bruiser (Frost white/Black top/ Light Blue interior)
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  4. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
  5. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Can you run one of these and your ac in on the same engine?
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    That is a great question. I want to do this on my 406, as I have the serpentine belt setup and AN OPEN AIR-PUMP SPOT ON THE MOUNT. (You can see what I mean on my website on the TPI 406 page). Gotta figure out if one of the "shorty" air conditioning compressors will fit in that slot, and if so I am set.
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  7. BUDDY
    Apr 28, 2000
    744
    Midland, TX
    Here's a dual setup:
    http://uscom.com/~lobel/dblpump.html
    If you look through all of those links and these:
    http://\http://www.onboardair.com/
    you should be able to figure out how to get on board air on just about any vehicle. It just takes a little research and some planning.
    HTH,
    Buddy
    I've got my dream truck and it's a 72 K-5 that is getting there!!
  8. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    I agree with Blazzin. I have that same setup, but i don't know how the belt would run? I would like to use that empty space where the smog pump is suppose to go but i would also like to run the second compressor off it's own belt. maybe someone has done this before?
    http://k5junkie.coloradok5.com/
  9. BurbinOR
    5,829
    Oregon
    The original belt would fit, considering the pump was once in there. We gotta check into this!!!!!!
  10. edeslaur
    edeslaur Registered Member
    Oct 31, 2000
    69
    Portland, Oregon
    Has anyone considered that Chevrolet engines, even the gas-powered ones, were put in an awful lot of trucks that used air brakes and that the brackets, compressors, etc. are likely readily available in some HD truck wrecking yard?
    When I get around to adding air, that's where I'm going to start my research...
    Eric D
    88 K30 Blazer
  11. BurbinOR
    5,829
    Oregon
    Hey Eric, you must be the same guy on bushhackers, correct? Where in Portlandia do ya live, I am in Gresham.
  12. edeslaur
    Oct 31, 2000
    69
    Portland, Oregon
    I live in OR City, but work in Portland.
    Yep, I'm the bushhacker with the red Blazer. :-)
    ERic D
