AC compressor leak.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by heavy4x4, Dec 25, 2002.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, I had the dreaded mystery fluid on my driveway this morning (what a christmas present /forums/images/graemlins/rolleyes.gif) Well, I wasn't about to pull out the wrenches today, but I did figure I'd locate the leak. I popped the hood and noticed fluid coming from the back/bottom of the ac compressor (the unit driven by the serp belt). The fluid was dripping down the front surface of the engine and collecting in a small puddle on the driveway. Not a constant leak now...seems to have stopped...but when it was dripping, I could hear hissing...like it was under pressure. The compressor, if I recall correctly, is run when using the defrost mode (which I had been, yesterday). So, onto my question...has anyone had this problem before, or does anyone know what I should look at first tomorrow??? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
    Oh yeah...and what is this fluid anyway...is it refrigerant??? Harmful??? The unit does have the high pressure lines going to it. I'm not planning on bathing in the stuff, but is it harmful to deal with (or is it just coolant?)
  2. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Sounds like your R4 compressor expired....that fluid is refrigerant oil...not harmful.
    Azblazer
  3. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for the reply. Does that mean my compressor is shot? How much are new/reman units?
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    The compressor will probably cost in the neighborhood of $150to$200 to buy, but it requires special refrigerant equipment to work on the system legally (R12 refrigerant). you need the system discharged, the compressor changed, and the system pumped down and refilled. It would probably be a good time to switch to R134A refrigerant, it will be a lot less expensive than the R12.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yep, now is the perfect time to convert it.
  6. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for the help. I called the local parts store, and they said the R4 compressor is $205. But, looks like I won't need it after all....well, yet anyway. I drove my truck around a bit this morning, and no more leak coming from the unit to speak of. I'm hoping it was some weird little fluke that has now gone away, but I'm sure it will be back...eventually.
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You might have lost the pressure in the system and now it wont leak anymore.
  8. heavy4x4
    Aug 28, 2002
    3,270
    I agree...if it needs changing...I'd love to go with the alternative refrigerant. BUT...Wisconsin has some crappy laws about refrigerant, and for some reason (if I remember correctly), the one metioned is prohibited for use in Wisconsin. (If it's the stuff that can be bought in a spray can type thing, then yes, that is illegal for use in Wisconsin. Don't ask me why /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif)
  9. heavy4x4
    Aug 28, 2002
    3,270
    That's kind of what I was thinking. The defroster still runs strong...I tried it out this morning. So...I'm clueless as to what happened/whether it's going to happen again later on. I didn't try the AC (plenty cold outside /forums/images/graemlins/smirk.gif), but it hasn't blown super-cold air for years anyway.
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    looks like you can forget about it untill spring anyway. /forums/images/graemlins/wink.gif
