AC Compressor ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JROSS, May 3, 2004.
  1. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    What is the difference between a switched and non switched Compressor. I was getting info for one and the parts guy asked me which one I needed but he didn't know the difference. I don't have one to compare to.
  2. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Hmmm, thats a weird question. I would say that your 1981 would use a switched compressor. I have never seen a Harrison/Fridgidare compressor that did not have a connection for wiring in the low pressure cutoff switch, which is usually located on the accumulator. (big silver can right hand side on firewall) /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Didnt know there were seperate styles. Maybe for yours there's some sorta overide switch?
  4. oldtoyboyd
    oldtoyboyd 1/2 ton status
    Nov 12, 2003
    904
    3
    Leesburg, MS
    It should be referring to a high pressure cut out swith on the back of the compressor.
