AC/DC power inverter
Discussion in 'The Garage' started by Hossbaby50, Mar 4, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My dad bought me a Coleman 800 watt power inverter. The manual says not to hard wire it to the truck? Why is this? I imagine it might drain the battery. How can I hard wire it and not drain the battery?
    Any recommendations on where to mount it? Thanks
    Harley
  2. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    I don't know about Coleman but we have a 1500 watt Vector on my wifes GMC Safari that we use for the Playstation and such and it's wired directly to an accessory thru a relay so when the ignition is turned on the inverter kicks in.. Had it since 2000 and no drainage probs yet.. The ground has to be as short as possible tho'
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Put a switch on it. You can also use a relay that is wired to an ignition wire and it will only work when the key is "ON". Be careful as that inverter uses 67 amps in 12V for a 7 amp toy in 120V
    800W/12V=66.66666A
    800W/120V=6.6666A
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I saw those on sale @ Checker. IIRC, they wer $49.99. I changed my mind, though, cause Pep Boys has one for $99.99 that is 1200 watts.
    Anyways, I was told the best thing to do was hard wire it to an acceptable switch. Then you can just hit the switch when you need to use it.
