AC/Fan problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Low76K5, Mar 22, 2006.
  1. Low76K5
    Low76K5 Registered Member
    Jun 28, 2005
    33
    Rapid City, SD
    Hello,
    A couple quick questions for you knowledgeable types.
    #1-My AC is wimpy. Is the stock AC in a 76 worth trying to recharge or do they just not work very well?
    #2-The minute I switch on the key with the heater controls set on "off" the heater blower fan turns on at a very low speed. Should I try replacing the control box? The underdash stuff is all stock and untouched.
    Thanks,
    Scott
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    when my a/c in my 75 was still there, it blew ice cold.
    the fan will blow 100% of the time even in the off position at a very very slow speed, its just how gm wired it. they are all like that
  3. Desert Yeti
    Desert Yeti 1/2 ton status
    Mar 20, 2003
    320
    Tucson, AZ
    Yep, fan is always on if the key is on, even when switched "off".
    It's been my experience with several different 70's GM vehicles that when the AC is working properly, it's nice and cold, although the volume of air moved by the fan leaves a bit to be desired when compared with newer vehicles.
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    #1 - Before you spend $$$ on an R-12 fill, you might want to have your system leak-checked. It would suck to pay the bucks for a recharge, and end up leaking the refrigerant into thin air.
    #2 - As the others said, it's normal.
