ac/heater blower doesnt blow... Where do I start troubleshooting?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dasanii19, Dec 7, 2006.
  1. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    Topic say it, my ac/heater does not blow at all when I turn it on, I have no idea where to start looking for the problem besides the fuse. Any ideas?
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Do you have power at the motor itself? Start there and work back if the fuses are good and there is power leaving the blower motor switch.
    Also check the resisted pack on top of the blower housing in the engine compartment. They are notorious failure points.
  3. dasanii19
    Oct 11, 2006
    344
    NV
    Thank you, I will start there and post back with what i find. I hope this is a simple fix.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Check that the plug for power on the housing is not loose or fell off completely, it's common, also the resistors inside the box like he said.
    :D
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I've had this problem on two of the K5's I've owned. There is a ground wire at the blower motor that corrodes and the connection dies.
    Rene
  6. dasanii19
    Oct 11, 2006
    344
    NV
    Ill check out all this stuff after work today.. Thanks
  7. dasanii19
    Oct 11, 2006
    344
    NV
    Well I atleast got it to blow and am getting heat, but its not blowing that hard. Also it seems to be having trouble activating, I mean when the lever is in the off possision I have to very slowly start switching it on (im talking about the upper vertical heater a/c lever), if I dont do this it wont work (meaning wont blow at all, I just get nothing). Sometimes it takes a few tries to activate it..
    Anyone know what is going on here?
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Spray some WD40 in the sliders area, you have oxidation on the contacts.
    Or you could change is, but I would just clean it.
    You can take it out and clean the contacts and put some contact grease and it will perform flawlessly.
    And if it's not blowing as hard as you want after you fix that sliders, then you could change the blower (easy job) and get the HD blower.
  9. dasanii19
    Oct 11, 2006
    344
    NV
    sounds easy enough, ill start by cleaning the sliders up. I would like it to blow harder. Is the HD blower the actual name of the unit I need to get? can you get the HD blower at any napa/ ac delco auto part store? How much am I looking to spend on the HD blower?
    Thanks, very helpfull. Everything seems to be coming along smoothly (knock on wood)
