AC high idle on a non-TBI truck
Discussion in 'The Garage' started by dremu, Sep 15, 2006.
  1. dremu
    Feb 27, 2000
    15,954
    444
    East of San Francisco
    All this talk about upping the idle for OBA has me thinking...
    but my truck is a '74, carb, no computer. It had AC, though I've yanked all the stuff off ... and it's a bit of a bastard, '75 style hot-air choke and no idle stop solenoid that a '74 should have.
    Anyway, is there an easy way to engage whatever system this carb uses to up the idle when the AC is on (was there such a system)? Or should I just get a manual choke cable? That might be kinda fun for crawling anyway...
    -- A
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If your Q-jet has the threaded holes for the solenoid , get a solenoind , and then you can run a switched 12 volt source to it to engage it . Pretty simple in your case :thumb:
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    you could also fab a bracket to hold a solenoid if there are no screw holes for factory bracket. Should be pretty eays. just use a manifold bolt hole or something close to the throttle.
    Junk yards are ull of the solenoids. Home depot has all sorts of hardware to make brackets out of...
    Did they make qjets without ac solenoid provisions?
  4. dremu
    Feb 27, 2000
    15,954
    444
    I could fab one, yes, but I'm lazy, and would rather use factory stuff if possible.
    Had to look in the factory books, but lo and behold, yes, the M4MC is *supposed* to have an AC solenoid, but mine was stripped off before I got it ... so to the Pick-N-Pull I go, and I'll get hooked up :)
    Thanks all!
    -- A
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The factory one is adjustable for speed too . The plunger end is a hex and you turn it with a 1/2 inch wrench to determine the length of it . A few minutes and someone looking at your tach for ya and your golden :thumb:
  6. dremu
    Feb 27, 2000
    15,954
    444
    Looking at the tach? Nah, a real man does it by ear :haha:
    Sweet -- didn't know that, thanks. One of these days I gotta sort out the fast idle on my '74, come to think of it.
    Is that solenoid ONLY used for the AC, or is it also used when the engine is cold?
    -- A
  7. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    My QJet has one but it is not for AC (no AC) or cold start. It is for deceleration. I guess it helps the engine by letting it down slowly. it is vac operated so the higher the rpm, the further it goes up. When you let off the idle, it goes down fast but keeps the throttle from slamming back too fast. Seems to run the same to me with or wothout it...
    The cold start is a cam connected to the choke.
    Mine is a 1982 hot air choke quadrajet.
  8. dremu
    Feb 27, 2000
    15,954
    444
    Vacuum operated? I'm thinking electric solenoid ... how does this vacuum thing work?
    -- A
  9. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    it vworks on vac pressure. It also has some wires that go to it. I think it is dual purpose. Either vac or electric. not sure though...
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I would of thought the hot air choke would of been gone by 81 . I have one in the garage , I should run the numbers on it see wht year QJ it is :thumb:
