AC light blinking?
Discussion in '1992-Present Chevy & GMC models' started by Dieselmh, Dec 30, 2002.
  1. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    Here's the trouble I'm having with my DD, it's a 1991 Chevy Extended cab truck with the TBI 350. The AC light blinks every time I turn the truck on. It's the little light on the panel that tells me when I have the AC turned on. When I start the truck, the AC light will blink for about 5-7 minutes, then go off. The actual compressor doesn't turn on, just the light. It's not a big deal since I rarely use my AC, it's just annoying, and after about a week of this, I can't take it anymore! Just wondering if any of you have seen this before, and may know what's causing it. Is it a warning of trouble to come, or just something that needs to be reset? Thanks for the help.
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    It seems like I remember my mom's 92 Blazer doing that one time. Try disconnecting the battery cable for a couple minutes and see if that fixes it.
  3. Dieselmh
    910
    Texas
    I tried disconnecting the battery last night for about 10 minutes, but that didn't help. Thanks for trying.
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    It's telling you that your low on freon. You either are just low, or have a crack in the system somewhere.
  5. Dieselmh
    910
    Texas
    Sweet! I was wondering what it meant. Since I don't use the AC, I never knew it was low! I guess I'll see if it's leaking or just low, if it's a leak, I'm just gonna learn to ignore the light! Thanks.
  6. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    If its low, it's got a leak.
  7. Dieselmh
    910
    Texas
    I thought that all systems kinda "lost" a little bit of freon over the years? It's a '91 truck with 250,000 miles on it, and I've never done any kind of AC work on it. If it's got a leak, it must be a really small one. I'll take a look at it.
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    If you dont care about the AC you can trick the sensor so it does not blink any more. Just put a jumper accross it. At the same time, unplug the compressor so it does not try to fire up when you turn on your defrost.
  9. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    They do, but it's because it slowly leaks out. Freon is not used up, and will last forever as long as it doesnt leak out of the system. However, most cars develop leaks after a while because of the many fittings and harsh conditions.
    Most leaks will have oil around them and can be found with with a mixture of soap and water. They will usually be around connections or in the compressor itself.
