AC peeps??? HELP???
Discussion in 'The Garage' started by 4xcrazy, Jul 22, 2005.
  1. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Instead of re-typing everything,,,here's a link, to a supposed AC tech site,,,so far not much help,,,hmmm, maybe i have them baffled as well :thinking:
    Read through it, and give me some ideas,,,am i forgetting something? did i do something wrong?
    I have never had this much of a problem with charging the system as this...
    EDIT,,,guess it helps if i put in the link,,,HUH?
    http://acsource.net/acforum/viewtopic.php?t=557
  2. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Guess i have everybody stumped on this one huh? :thinking:
    I suppose i will just replace the compressor,,,maybe something internally is messed up with it,,,i dunno :(
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Is it possible to be pumping the refrigerant in the wrong direction? Is the condensor cool?
  4. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Was there metal on the original orifice tube? If so, then you need a compressor. Are you pulling a vacum with an electric vacum pump or an air powered one?
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Electric vacuum, for quite awhile, dissconnect, and holds vacuum.
    No metal in the original O-Tube, is it possible to get a bad one? from new?
  6. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    ok... lets rewind.... you vacuumed the system, and held it... at what pressure and for how long, and what was the ambient temp when you did that?
