AC problem....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by btolenti, Aug 11, 2004.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    ok,
    mt AC is on the blink. When I put it on, the compressor cycles on and off constantly (on for 1 or 2 seconds, off for 1-2 seconds, then on again, off agin, etc)....and it never gets cold. The Compressor is also extremely hot to the touch even after just a minute or so of "cycling"
    Do you all think this is just a lack of Freon or a bad compressor? It also makes a lovely squealing sounds when it is on...
    /forums/images/graemlins/dunno.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    First thing I thought of when it short cycles , is freon level . Find someone with gauges and look , or stop by a pawn shop ( they always end up there ) and get a set cheap /forums/images/graemlins/k5.gif
  3. blazup1x
    blazup1x Registered Member
    Jul 26, 2003
    30
    Carlsbad, NM USA
    Sounds like its low on freon and a clutch going bad! Hey it sounds just like my unit. Check on ebay there is a guy selling reman A/C's for your Blazer for $25 I ordered one for my self seems like a good deal.
  4. 1-ton
    Apr 17, 2004
    2,882
    161
    Las Vegas, Nevada
    The squealing sound is probably the bearing going bad, and the constant on - off cycling (as already stated) is probably low Freon causing the high-pressure cutout switch to activate. I would say you need a rebuilt compressor.
  5. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    How reliable are the remanufactured compressors??? Do you all think Napa has the best parts???
  6. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    [/ QUOTE ]YOu will probably spend less buying a brand new pump from Napa. I have gone through 2 napa premium rebuilt pumps in 2 years. I have spent more money in buying freeon and having the system flushed and recharged , acummulator dryer & orifice tube,if I would have paid the extra $120 for a new pump and just did everything else once.
