AC Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Peeetah, Aug 4, 2000.
  1. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    I just replaced my belts and now my AC compressor clutch keeps engaging and unengagin when I have the AC on. Also when the clutch is engaged the engine RPM lowers while it used to be higher before this probelm. Any thoughts???
  2. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    I'd say you are low on freon and the low pressure switch is kicking in. I'd also say the idle control solenoid isn't engaging when you turn it on... It raises the engine speed to compensate for the increased load.
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
