AC question
Discussion in 'The Garage' started by 1977k5, Feb 22, 2007.
  1. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I replaced the air conditioning condensor on my car and now the system is full of air. I don't have a vacuum pump and the cheapest I can get a local shop to pull the air out is $60 :rolleyes:. How important is it that I get the air out of there? I have heard that the only reason you need to pull the air out is to avoid moisture and contamination (it is very dry here). I really would like to just refill the system and be done with it. TIA
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    When I lived in Colorado Springs, I got the guys at the brake place attached to Advance Auto Parts (Brakes Plus, maybe?) to vacuum my system for $25. They just hooked it up and let the pump run for an hour. Then I filled 'er up with r134a myself.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    No matter how "dry" the air feels there is still moisture in it. The moisture will combine with the freon and create an acid that will cause corrosion inside the system and it will eat all of the orings. Also even though the can is pressurized you need the extra difference in pressure of the system in a vacuum on top of the can pressure to normally get a full charge in the system.
    Have it evaced and do it right or you will get an opportunity to do it again in about 2 weeks.
    Ira
  4. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    autozones down here will loan a vacuum pump.
  5. 5280k5
    5280k5 1/2 ton status
    Dec 18, 2005
    1,175
    Aurora, CO
    How 'bout we just do it for free! PM'd ya:D
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    After a vaccum is drawn on the system, besides removing moisture it will make the refridgerant more efficient for the closed system. Vaccum is very important for an extremely effective a/c system. I cant remeber why my book said so exactly and Im too tired to try to think about it and explain. I will look it up later and post what it says exaclty, that is of course if someone beats me to it which would be appreciated.
  7. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    i've used the engine vacuum before when i was real desparate. works pretty good, just kinda goofy to hook it all up.
  8. sandawgk5
    Oct 28, 2003
    6,881
    It has to do with the something called a Mollier diagram. Different fluids boil at different temps these temps change with pressure. Freon works as a refrigerant because R-12 for example boils at 32F. When it boils it is removing heat from the air (almost like evaporation inside the pipe). Now if you raise the pressure in the system the subsequent boiling point will also raise therefore it will no boil at say 45F for instance. You can see how you system would not be as efficient.
    Ira
