AC Swap
Discussion in 'The Garage' started by skink4president, Jul 1, 2005.
  1. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    Rumor has it that I can swap out my old (and HUGE) AC compressor and bracketry on my '73 K5 for a smaller, later model setup. Has anyone done this swap? Any advice?
    Thanks!
  2. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    I just had my ac charged and checked for leaks by my mechanic buddy at his shop. He told me I have the good compressor, the really big one. Said they are low cost to replace and out last the other pancake model. Just what I know. :)
  3. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    I've done the VintageAir swap in my 72 K5.
    But it sounds like you are talking about later model GM parts.
    If you are interested in the VintageAir conversion let me know.
    I don't know what they offer for the 73 and later though.
  4. skink4president
    Mar 5, 2005
    79
    orlando
    Yeah! My current compressor can be replaced for under $100. The guys at the parts store couldn't believe it and thought it must be a mistake. I only want to swap it out to lighten things up and go with the later model bracketry which (I've been told) will allow tall valve covers. Also, I don't know if you've noticed but the OEM compressor is VERY securely fastened to the engine. There's like four different brackets and a dozen bolts!
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My compressor is cheap too , I have the radial r4 , the darn clutch ( all I needed ) was 85 dollars , the whole thing with clutch was 89.00 . Now old one sits on shelf , couldn't bear to pitch it its original :D
  6. skink4president
    Mar 5, 2005
    79
    orlando
    Boondocks -
    Are you happy with your Frontrunner system? What about the other stuff from Vintage AC? I assume you weren't replacing an existing system but rather starting from scratch.
    I really need to get my existing AC up and running and while I'm at it I'd love to clear out the old brackets and pulleys but I'm a little tentative about spending well over $1,000 for the Frontrunner system. Also, where'd you purchase?
    Thanks for the advice.
