  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I have never used my AC since I bought my truck 3.5 years ago. I took the ac fan belt off cause I lived in Ak and never needed it bu now I am down in CA and I will need it here soon. So I know I have to replace the belt but what else do I need to do to get it running?
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    put the belt on and see what from that point what is not working
    you can take the cap off the low side and see if there is any freon in it
  3. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    I'm no an A/C expert at all so take it for what its worth but I think you're system uses the freon as a lube for the compressor among other things. You may run into a bunch of problems trying to get it up and running after 3+ years of it not being in use. I would say take it to a shop and get them to check it out but if you're wallet is anything like mine that may not be an option.
