accel supercoil?
Discussion in 'The Garage' started by 1BadK-30, Feb 6, 2007.
  1. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    I searched and really didn't find a answer, I have a accel cap and rotor HEI kit on my 78-79 350. I heard its supposed to create better spark and performance, is that true? Just trying to figure if its worth the extra change then the stock unit.
    Thanks guys.
  2. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i have one and can't tell the difference.:D
  3. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Yaa, from what im finding its like half get performance and the other half dont see any.
  4. dyeager535
    26,979
    Accel coils had a pretty good reputation awhile back, not sure anymore, so perhaps when yours quits (if ever lol) then "upgrade". Otherwise I'm with the "can't do any better if stock is working right" crowd.
  5. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    A factory HEI is a very good ignition system. Other than possibly starting faster or burning off more fuel if you are running rich or overcarberated you won't be able to physically tell the differance. I usually use an MSD with the stock HEI coil. I just put an MSD coil in because my factory one went out. The reason is that I may not feel a power gain but I know I am getting a bigger spark as well as multiple sparks per revolution of the motor, therefore burning off more exess fuel than the factory setup.
  6. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    its been on there sense 1991, Sense i recieved the truck im just wondering. I thought the 30 bucks was kinda pricy for a cap and rotor.
  7. goldwing2000
    goldwing2000 Guest
    Ditto.
  8. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I got the super coil on mine and it made a big difference, but I was also going from points to HEI, so that alone is a big difference. Before I switched I had the points type super coil and couldn't tell a difference.
  9. damewood
    damewood Registered Member
    Oct 6, 2005
    9
    WV
    accel coil
    i have had 2 bad experiences with them,so i shy away from them anymore
  10. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    I'm not a huge Accel fan.. They had gotten to be a company living off their name.. similar to Champion...
    Tho they have come out with some new offerings in recent years, so that suspicion may be unjustified...
    Either way, I don't think there's an ignition company out there that compares to MSD... I went from mallory stuff to MSD years ago and have high confidence in their stuff.. Not that Mallory was horrible, I just really like MSD's products...
  11. boggerless
    May 26, 2003
    22,728
    96
    the cap and rotor are not worth it.AC Delco baby.:bow: cheap and last longer. the accel plugs are garbage.:haha: do the still make those plugs???:laugh:
  12. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Not sure, It's allways had Delco plugs in it.
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Mr. Trashket bought Accel somewhere about '98 or '99. They dumped nearly all of the worthwhile Accel Ign products & re-badged Mallory crap with Accel labels. Guess they had to sell it somehow.....
    Maybe in the days of points there was a need for a super coil on a mild engine, but these days the stock coil will do a danged good job.
    If the HEI has a performance issue it's the module, not the coil.
    For the money I'd rather have a Crane HI-6 than an MSD 6 since those come with the rev limiter built-in instead of as some hokey, oversized add-on box. And the limiter can be adjusted with a small screw driver, no parts to buy!
    For wires I've found Magnecor to be much better than MSD wires. We once had a serious EMI/RFI problem on work's dyno and MSD's 8mm wires made no difference. MSD's 8.5mm wires didn't either. Put a set of Magnecor's on and the problem disappeared.
