Acceleration problem?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rick, Feb 11, 2003.
  1. Rick
    Rick Registered Member
    Oct 12, 2002
    16
    Bonifay, Fl.
    I got a problem, my truck seems to lose power after 65 you step on the gas and it makes alot of noise but it don't move, it even downshifts, at low speeds its perfect, we've checked the timing and there's no black smoke so I don't think its getting flodded, anyone ever had this problem. Thanks in advance for you're help
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    weak torque converter is my first guess
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Are you positive your timing is good? Lack of performance at higher RPMs generally means you've got too much timing into it. If the advance bushings are worn out in your distributor it can be a real bitch to time properly.
    What is your timing set at right now? When's the last time you popped off your distributor cap and checked if everything is tight and properly operating?
  4. spitfire
    spitfire Registered Member
    Feb 8, 2003
    40
    Phoenix, AZ
    My brother has an '85 and it has the same problem. We were told it was his overdrive gear in his 700-r4. It sucks. There is almost no throttle response on the highway.
  5. Can Can
    15,552
    136
    Just so you know, brother, OD in a 700r4 is not for performance, it's for steady cruising. If your TV cable is properly adjusted, a 700r4 will kick down into drive at about 2/3 throttle. It sounds to me like his tranny isn't gearing down when it's supposed to.
    Also, gearing can play a big role. What gears does your brother's truck have?
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Fuel filter?
    How long has it been since you changed the fuel filter ?
