Accelerator spring.......is it fixable?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Jan 10, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    As most of you probably know, I have recently purchased an '88 K5. All is going well, except for that fact that I have to stomp my foot to get the accelerator to go. Like any other vehicle, when you make a sudden start, your head goes jerking backwards. Plus, it's also really hard to try to keep a constant speed with it like this. I really want to get it fixed SOON!! Thanks
    Alex
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    lmc sells springs for the accelarator.
    i kinda need one, but its not a emergancy.
    let me knwo how it goes....
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    The spring on the carb that returns the throttle? You can buy those at (GULP) Autozone or any parts house. Probly even get one from Ace Hardware.
    creepin' and crawlin'
    Jim
  4. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Yeah the throttle return.....so when you let off the gas the pedal comes back. How hard are they to take off and put back on??
  5. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    They aren't that bad to work on. However, it sounds like your acc. cable may be in need of some lubrication. When you take off the spring, take off the acc cable connection at the carb and see how hard it is to work back and forth. It should move freely.
