Accesory position?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudfanatic, Oct 1, 2000.
  1. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    did 1977 blazers have an accessory position on the switch? since my key won't twist back into what should be the acc. position did somebody change the ignition switch, or the key cylinder? or is this just a simple fact that maybe the tumblers in the cylinder have gotten sloppy and won't let the key turn backwards anymore? FYI I can turn the switch all the way to the start position without using a key.
    PS. I hope that none of you ever have to go through adjusting or replacing your neutral position sensors, I have mine off and can't seem to figure out how to get it lined up right... what a bi***
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    I dont know about 77, but my old 80 had an accessery position. I imagine that is going to be an issue with your key. Goodluck and good morning. HAVE A NICE DAY!!!
    http://dblazer.coloradok5.com
  3. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    I'm starting to have troubles with my 91's ignition switch going into the ACC position. My troubles are the key and tumbler. You can pick the set up from Auto Zone for about $15.
  4. Chewy
    Chewy 1/2 ton status
    Sep 4, 2000
    197
    Parker, Colorado, USA
    My 87 and my buddy's 85 will not go into the accessory position.
    '87 Beast
    Colorado, USA
  5. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    On my 91 I have to jiggle it a little but it will go.
    blazen91
  6. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I have trouble turning the key to the accessory position in my '89, but I can still get it there after a few attempts. Sounds like a common problem. It's on my fix-it list.
    '89 K5 Silverado 4" lift w/BFG 33's
  7. 89GAK5
    89GAK5 Registered Member
    Sep 18, 2000
    22
    GEORGIA
    me too: no acc position.the thing seems to be eating my keys they ware down pretty fast.thats another thing on my list.
  8. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Mud, yes your K5 would have an accessory position. Don't know about the changing of the ignition thing, but if your key is really trashed that could make your key not work backing into that position. (or the ignition might be worn out) If the key is too worn to duplicate you can get a new one made with a code. Sorry, but I can't remember where to find the code, but once you get it you can go to a dealer. Good luck!
    You can't beat going Topless!
  9. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    My 88 has some trouble going in but after a few attempts it will. I have to kind of push the key in towards the column til it catches and slips back. Need to take a look at it.
    Have you driven OVER a Ford lately?
  10. angelglo
    angelglo 1/2 ton status
    Aug 4, 2000
    105
    S.F. bay area
    both my 75's dont go into the access. position. i dont think they have one. the keys also seem to work find when i start them.
  11. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Try playing with the steering wheel while going from off (locked) position to acc.
    Also try going fast from the on position all the way to the acc position.
    That works for me.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
