Access to wire to door jamb switch for dome lights?????
Discussion in 'The Garage' started by mattman, Nov 10, 2004.
  1. mattman
    mattman 1/2 ton status
    Feb 15, 2001
    152
    Austin, Texas
    The dome light in my suburban kept coming on and off. Whenever the passenger door was opened and shut it would go out. I pulled the switch out of the door jamb but the wire came off. How in the heck do you get to the wire to get it through the hole to put it back on the switch?? Everything I try seems to indicated I can't get to the wire. I don't want this to short since it is a constantly hot wire.
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I had to pull it out from the back, under the dash. Then sent a coat hanger through the hole in the door jam up to underneath the dash. Tied wire to coat hanger, pulled coat hanger out of the hole.
    It sucked, but worked.
    -Chris
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I thought that wire was a ground wire not a hot wire
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Just fish in the hole with a thin piece of rigid wire bent into a hook. It's easier to grab than you think, trust me.
  5. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    The wire to the jamb switch is a ground wire--it wont burn or blow fuses if it grounds,but it will make the dome and courtesy lights come on--kinda spooky when your driving alone!. /forums/images/graemlins/shocked.gif
