Accessories on a side post battery
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Jan 16, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I just got my blazer this summer and the battery is still really healthy otherwise i would have ditched it for a side and top post mounted battery. SO all I have is side posts(crap) and i HAVE to have a straight battery connection for a few accessories how should I do it big ring style crimped on and hope to catch enough threads to keep it tight or what? I have to mount my MSD, CB (Galaxy 44), and amp straight to the battery
    Granny LOW and let her GO!!
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Make a stout lead to an accessory fuse block on your fenderwell. I will be doing the block soon myself.
    Wrangler NW has a HUGE selection of cool goodies like that.
    Dave
    Rehab is for quitters.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    haven't thought about that lately! Perfect excuse for an AUX fuse box!
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Yes. 1 more thing the side mount post have removable lugs and there are replaceable lugs which have there own mini-lug attachments like the one that goes into the battery but on a longer internally threaded post. These are available in most part stores.
    Wrangler NW makes multi-piece lugs - wanna picture?
    Dave
  5. BowtieBlazer
    Jul 15, 2001
    2,462
    sure.....FisherXT@aol.com
  6. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I would like pics too. dawson444@aol.com Thanks!
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  7. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Dawson
    Raleigh, NC
  8. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I wouldn't go with a fuse block, fuses may be too small. Stereo shops carry power distribution blocks, which can handle bigger wire as big as 2 gauge - for battery to distrib connection). Then add in line fuses for what you run off the block. Thay have available terminals usually for 8-12 accessories, but bigger ones are also available if needed.
  9. BowtieBlazer
    Jul 15, 2001
    2,462
    Isaide fuse block but thats the type of fuse block i had in mind thanks for the concern
  10. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If you check out my dual battery project on my web page, you will see that I converted my side mount primary battery to a side post battery (got the screw-in posts at Walmart). Then I used the military-style connectors on the ends of my battery cables. These connectors are GREAT for adding additional wires. If my website doesn't have enough pics, let me know. I have better ones.
    I also have some good pics (but not on my website) of the bif fues panel I setup on my secondary battery that powers my auxillary lights and some other circuits. It accepts one wire in (up to 1/0 guage, I used 2 ga) and has 12 push-in fuse slots. I have six of the 12 circuits going from that fuse pannel to my big off-raod lights (910W of lights) and another powering my emergency dual battery switch.
    Let me know if you need more pics. I got the fuse block and most of my accessories from WranglerNW.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  11. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I used something similar to all thread and some nuts. The first nut holds the main battery cable on, then I use two more nuts to hold the rest of the wires in.
    I'll more than likely never go back to a top post again. This made it too easy to add stuff in.
    Kyle
    89K5
  12. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Emailed pics after trying to post in Memeber's Rides - encountered errors. Anyone else having problems in that area?
    Dave
  13. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    This block can handle 80 amps to each terminal or to a ganged set of 4. Must be the HUGE fuse type - is that ATO?
    The block can be clipped to more blocks of the same type.
    Looks HD to me.
  14. BowtieBlazer
    Jul 15, 2001
    2,462
    96C4and91K5:
    Thanks for the pics! Very Helpful! I appreciate it...
  15. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    NP. What type are you looking to get?
    Dave
