Accetone and carpet glue
Discussion in 'The Garage' started by 73K5Kid, Jan 16, 2003.
  1. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    Well I decided to Herculine my bed and cab. So I pulled out all the carpet and foam. And now I have pieces of foam and glue all over the place. What would be the best thing to use. I thought maybe Accetone. /forums/images/graemlins/1zhelp.gif Suggestions please
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Acetone will dissolve fiberglas resin, so it might be a little overkill. Laquer thinner or xylene is probably plenty tough.
  3. tRustyK5
    Jul 23, 2000
    36,164
    1,361
    E-town baby!
    A heat gun also works real well. It softens up the glue so it all comes off pretty easy. I'd use that first and then clean up the residue with Xylene.
    Rene
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Like Trusty said, Heat will do the job. I used a little propane torch and a putty knife. Move the heat around and won't catch on fire.
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Prep-sol.....or any wax and grease remover will work...
    When I did interiors and healiners....I used alot of that stuff....
    Soak-it.....let it sit for a few minutes....then scrape....
