acid dipping
Discussion in 'The Garage' started by muddybuddy, Feb 10, 2007.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    how many people have had old parts acid dipped? how much does it typically cost? i have no idea what to expect to pay, im thinkin about getting my rims dipped.
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I had a D44 rear axle dipped (completely disassembled) with the cover locally for 75$. And a dual blade lawn tractor deck done for $65.
    It does an awesome job...completely bare metal.
  3. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    The guys at the local NAPA when I was younger would do our bike frames for free. We would drop it off in the morning on the way to school and pick it up in the afternoon. Worked great and left a nice surface to start paint prep. I thought it was near impossible to find anyone who does it anymore.
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    when it comes to a rim why not just get them sand/media blasted? there are more guys doing that then acid bathing. My local carquest has a dip tank. they primarily use it for engine components.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I don't know one way or the other, but there are some who say you should never sand blast a steel wheel. Something about they break rather soon afterwards. Might be a wive's tale.......
    I know if you do that to valve springs that they fail pretty fast. A friend bought some off a guy who'd done that & the friend didn't know any better.
    I think I'd hedge my bet and go with walnut, plastic or corn cob blasting just in case.
    Left in too long acid dipping can reduce the metal thickness. That's an ancient racer's trick to take weight out of the car.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    well im looking to do it for my newly acquired h1's :)
  7. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I wouldn't do anything to those wheels that could potentially lead to the o-ring not sealing.
  8. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Check out MuddinManny's build thread. He had parts of his D60 dipped. Did a great job and was cheap. Your rims won't crumble away or anything like that.
  9. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I had it done on mine. I didn't actually look for a place on my own. The place that recentered mine mentioned that there was a place that they often use to do it, so I went through them. It was a bit pricey though. I was told it was 125, that was if it was 3 wheels or 6 ... didn't matter, whatever would fit into the basket/vat. So it broke down to 25 a wheel for me. In my case it was worth it. That paint the military uses is some tough stuff. It looked like my wheel had seen several colors over the years. Some were black, some were the desert tan.. but all had multi layers. It would have taken me forever with my little cheesey sand blaster. I wanted everything off, so that the chances of getting the centers on nice and true were as good as they could be.
    On mine they soaked them in stripper, then dipped them, then soda blasted them. All for that price.
    There was nothing different about my wheels afterwards, other than the fact that there was no paint on them. There won't be any O ring issues. Not to mention the PC I had done will be a much better finish for the O ring to seal against vs. some other options. I also have new O rings for all my wheels. so that should help.
    Before I made up mind to dip them, I tried brushing some brake fluid on one of the wheels to see how easy the paint would come off. I let it sit for a couple of days and checked it. It didn't even budge, no sign that it was doing anything to the paint at all. I sand blasted a little on another, and it was super slow going, but it started to rain, so I had to stop and pick up everything. But the little bit I did told me it wasn't going to be easy to get them clean.
    That's my experience with the wheels, others may have different experiences. I guess it depends on how much paint is on the each persons wheels .. as to wether or not it will come off easy. In my case, I'm glad I just had them dipped, it was easly the best option for me.
  10. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    humvee rims are CARC painted.... the stuff is made to be subjected to chemical warfare..... would be really cool if brake fluid kicked its @$$
    I say go for it. I hate CARC paint
  11. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
  12. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I would tend to agree with you except that I have seen wheels that were abrasively stripped, painted or PC'd and then cracked shortly after being put back into service.
    I can't explain it, I don't know why. Just seems like a place to err on the side of caution until the reason is known.
