Acid Rain spots on the glass??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CrazeeBush, Nov 24, 2001.
  1. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    Okay, not about my truck, but I figure if anyone knows the answer could benefit all. My Monte Carlo has these little brown spots on the windows. I couldn't tell it till I got my windows tinted a while back. I asked my tint man what it was and he said acid rain marks, he also went on to say he had no idea how to get them off. So my question is, how do I get rid of 'em? I tried vinegar since it seems to clean just about anything, and no luck... Anyone have any experience with this at all?
    -BuSH
    '83 K5 Blazer
    '98 Monte Carlo z34
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Try polishing or rubbing compound. I've used them to get hard water stains off of the glass on my cougar.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  3. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    you can also use tooth paste on glass no joke it works pretty well and removes most minor scrach o and plaque to
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Ask a glass shop, this is common, and the fix is something called 'sirium oxide'............
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  5. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Use rubbing compound with 0000 steel wool. Don't rub too hard. You can also make a buffing pad with the steel wool and use a slow rotation orbital buffer (NOT a rotary buffer- it'll leave swirls) to remove.
    Years ago we removed the same stuff from 400 UPS trucks, worked fine.
  6. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    I think I read in the owners manual (13 years ago) to use bon ami (?). It's used in cleaning pots and pans.
  7. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    The car lots use steel wool.
    1985 GMC JIMMY
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Eastwood has a kit for polishing glass. If you can avoid the steel wool I would recommend brass wool because the steel wool fibers will rust. Fine brass wool is hard to find but I think Eastwood carries it too.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  9. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Steph's Webpage&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I keep trying to lose weight, but it always finds me!
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Yep, regular paste toothpaste (gel doesn't work as good) is a good polishing compound for lots of stuff. I cleaned up some wiper tracks on a windshield with it once. Just be sure to clean it off any metal parts, because most toothpaste is high in sodium (salt) and can cause corrosion to form on bare metal.
    Ken
    <font color=blue>America--Land of the Free, Home of the Brave<font color=black>
