Ack! Help Kingpin Problems!
Discussion in 'The Garage' started by dhdescender, Jul 5, 2003.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I removed the kingpin cap to install my steering arm a month back, now on reinstall I cannot get it all together.
    I made a steering arm and a 1" spacer for crossover steering. The old kingpin cap was 1.575" deep (Can somone confirm this?? my cap is now cut up), so I welded a cap in my steering arm 575" up + the 1" steering spacer to make the spring preload the bushings correctly. Now it seems the stack height of the springs is WAY too excessive to ever bolt back up.
    Seems the two conical bushings under the spring wont seat correctly is my best guess... Are they supposed to sit flush on top of each other? I see the top bushing has a slot that fits in a keyway in the axle, but it STILL wont go down far enough, they dont seat correctly. Is there some trick to it?
    Help? If somone has a kingpin cap removed...I would also love to make sure I measured the depth correctly!!!
    /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  2. REDMANIAC
    REDMANIAC Registered Member
    Oct 19, 2001
    40
    I pretty sure you are off a centimeter with the measurements, I havent quite got my arms on yet, but Ive seen people compress the setup using a clamp to get the nuts started evenly. HTH-JESSE
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    2 conical teflon bushings? 1 per side?
