acrylic caulk,
Discussion in 'The Lounge' started by R72K5, Sep 12, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    anyone know if acrylic caulk can handle max of around 220 degrees water and 15psi in a thin layer ?
    just wondering cuz its good for sealing diff covers and such, well at least silicone caulk anyways, hmm..
    thanks
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What is it going to be used for? An acrylic caulk is not made to withstand those conditions really...there are better-suited products out there. Once you tell me what it's adhering to, I'll give you some better possiblities.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cast iron and steel
    thanks
  4. heavy4x4
    Aug 28, 2002
    3,270
    Does it need to hold the structure (tank?) together? Is it just sealing up corners and cracks? /forums/images/graemlins/ears.gif
    If it doesn't need to be pliable or ever removed, I would use something like a Plumber's Epoxy or JB Weld even. There are so many epoxys and sealants out there to choose from. Best thing to do is go to your local hardware store and start reading packages. My recommendation is stay away from acrylic caulk.
