Actual Air Force Maintenance Complaints
Discussion in 'The Lounge' started by Z3PR, May 2, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Here are some actual maintenance complaints submitted by US Air
    Force pilots and the replies from the maintenance crews.
    "Squawks" are problem listings that pilots generally leave for
    maintenance crews.
    Problem: "Left inside main tire almost needs replacement."
    Solution: "Almost replaced left inside main tire."
    Problem: "Test flight OK, except auto land very rough."
    Solution: "Auto land not installed on this aircraft."
    Problem #1: "#2 Propeller seeping prop fluid."
    Solution #1: "#2 Propeller seepage normal."
    Problem #2: "#1, #3, and #4 propellers lack normal seepage."
    Problem: "The autopilot doesn't."
    Signed off: "IT DOES NOW."
    Problem: "Something loose in cockpit."
    Solution: "Something tightened in cockpit."
    Problem: "Evidence of hydraulic leak on right main landing gear."
    Solution: "Evidence removed."
    Problem: "DME volume unbelievably loud."
    Solution: "Volume set to more believable level."
    Problem: "Dead bugs on windshield."
    Solution: "Live bugs on order."
    Problem: "Autopilot in altitude hold mode produces a 200 fpm
    descent."
    Solution: "Cannot reproduce problem on ground."
    Problem: "IFF inoperative."
    Solution: "IFF inoperative in OFF mode."
    Problem: "Friction locks cause throttle levers to stick."
    Solution: "That's what they're there for."
    Problem: "Number three engine missing."
    Solution: "Engine found on right wing after brief search."
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Already posted , but still too damn funny....
