Actual lift heights with 4" and 6" spring lifts..............
Discussion in 'The Garage' started by BurbinOR, Dec 12, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Actual lift heights with 4\" and 6\" spring lifts..............
    Guys,
    On the fence as to what size lift to put on the Burb...........it's either 4" or 6" - tire size WILL be 35's. I know with 4" 35's will fit but be close on flex situations, so a 6" would be a better choice. HOWEVER, if I remember correctly, someone (think it was Grim) said that most 4" lift springs give more like 6"...........so I am looking for real world experience from you guys and gals. If you put 4" on, did you get more than 4" of lift? If so, was it enough for 35's?
    Keep in mind I will not be flexing this beast much if at all so I am looking for 'road manners' clearance. I'd rather not have to change brake lines and stay at a 4" lift if I can.
    Thanks! /forums/images/graemlins/eek.gif
  2. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    Re: Actual lift heights with 4\" and 6\" spring lifts..............
    GO WITH THE 4"
    AND MAYBE JUST A LITTLE TRIM
    4" WITH 38'S
    350-350-203-44-12
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    The first lift I had on Emmett was 4"HD Superlift front springs and 35x12.50's on a 10" rim. This was nice for the street and afforded good flex with minor rubbing at full flex!
    Now I am running a 6" Superride forn spring and get a lot better flex, but I had to trim a ton and I still can shove a tire into the firewall!
  4. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Got a 4" lift with 35x12.50x15 on 8" rims and went through a shallow ditch while turning and ripped the chrome trim up about 3 or 4 inches. It was on the edge closest to the firewall. Real life experience. I need a trim with my 4" lift. /forums/images/graemlins/smirk.gif
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    resurrect a post titled something like "ride height" put up by me a while (year or so) back. Has some actual numbers of installed lifts. It's a good one to drag up from time to time. I think it's in the 73-87 K5 forum, maybe Fox can transplant it over here since this seems to be where it belongs.
  6. nvrenuf
    Jan 7, 2002
    13,074
    245
    Mobile, Al.
    Also try searching under "Rugged Trail", there was a thread recently discussing that these kits were generally the tallest when compared to same size lifts by other brands.
  7. Big10
    Big10 Registered Member
    Aug 30, 2002
    84
    Georgia
    I installed a Rough Country 4" all spring lift about 3 months ago. My actual lift was close to 6.5 inches in the rear and about 5.5 inches in the front. I ended up putting longer shackles in the rear to level the truck. ( so i ended up with 5.5" front and rear). Also, I run 35x12.50x15 tires on 10" (4inch backspace)rims. I dont have any rubbing and I have flexed it pretty good a couple times. /forums/images/graemlins/thumb.gif
  8. Taylor
    Taylor 1/2 ton status
    Jul 17, 2002
    326
    Elizabeth, CO
    I installed a set of Skyjacker 4' front springs and got 5.25', makes my 33's look tiny! Wish I would have started with 35's.
  9. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Taylor, same thing here! I got 5.25" out of the Skyjacker softride...you want flex, get this kit, but make sure you get shocks with lots of travel.
  10. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Thanks, Steve. Thats a good post.
    Ride Height
  11. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Gotta remember with the measurements some are giving, after installing a new lift, the numbers will go down due to settling.
    All aftermarket lift kit manufacturers will confirm that the springs will settle over time. They average about 1" of settlement, depending on the accessories the vehicle has.
  13. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    6in lift shock for a 4in lift then?
    For 35's I like the looks of a 6in lift
  14. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    I know this is a PITA but best thing is to put on the springs and try to measure full droop and full stuff then get the right size.
  15. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    I would go with the 6inch lift. this way you wont have to do any fender triming. A 4inch lift with no triming will be close with 35s. I saw a chart in a magazine awhile back and it said that you need 6inch lift to run 35s with no triming. you also have to remember that a new lift will settel after a few miles.
  16. 71RestoRod
    Mar 7, 2001
    178
    Evergreen, CO
    Thanks Dan... I was looking for but couldn't find that thread.
