Adapter plate 700r4/TH350 to 205...
Discussion in 'Parts & Trucks Wanted' started by TONYP, Sep 30, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    if I can't find one then I making one up, but would rather find one...mine broke and has been welded up but want to replace it... /forums/images/graemlins/usaflag.gif
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Re: Adapter plate 700r4 to 205...
    I have one- brand new in the box. It even has the instructions and piece to modify the TV cable to use as the kickdown cable on the T350. I want only what I paid for it:$70.00. I'll even ship it to you for that price.
    PM me if you want it.
  3. TONYP
    Aug 13, 2002
    2,116
    so cal
    PM'ed you... /forums/images/graemlins/thumb.gif
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You might be the man for the job here. Have you looked into machining an adapter plate for the 700R4/205 that is a little longer so that you don't have to swap to the th350 output shaft or grind the 700's output. Might sell well. I personally don't need one, but it might be a good product.
  5. TONYP
    Aug 13, 2002
    2,116
    so cal
    ok, i'm learning on this one...
    I need a 350/205 adapter plate as this will be used for a 700r4/205 adapter plate...
  6. Mobile_Mechanic
    Mobile_Mechanic Registered Member
    Jul 17, 2001
    88
    Phillipsburg, NJ
    You and me both. I broke mine last weekend.
    The adapter will bolt to the 700 just like the 350 but the out put shaft stick out is longer on the 700. You chave 2 options. put a shorter out put shaft in the 700 or a small adapter in between the tranny and the stock adapter.
    either way we still need the stock adapter.
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    just called (the toy shop trans) the place who built it, and he said they use the adv.adapter out put shaft on the 700, so I just need a new 350/205 adapter plate...
  8. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    hey Tony i think its time to warm up the CNC :-)
    ill pm ya
  9. TONYP
    Aug 13, 2002
    2,116
    so cal
    might be time...I have two guys that will loan them to me and I have one on my truck that when I do the change over I could use...they look as hard to find as the np205 is...and I'll have a th305/np205 to sell soon... /forums/images/graemlins/deal.gif
  10. TONYP
    Aug 13, 2002
    2,116
    so cal
    ttt
