Adapter plate seal 700R4 to NP241
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by along4, Nov 1, 2002.
  1. along4
    along4 Registered Member
    Jan 1, 2002
    25
    Prescott, AZ
    I am converting a 1991 Blazer to a 700R4 from a T350 (long story). I have all of the parts now, but am seeing that the space inside the adapter plate is will have fluid in it from the transmission. I do not see if there is supposed to be a seal between the transmission and the adapter and also the transfer case. Can I get away with formagasket? Thanks. /forums/images/graemlins/grin.gif
  2. transcore1
    transcore1 Registered Member
    Aug 15, 2002
    44
    Clean both surfaces and use a high quality RTV Silicone. Will work fine.
    Scott
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    There is a thin O ring that goes on.
    Poeple here seem to like the RTV better but I never had problems with mine, and I owned a lot of them, when I installed agood seal and carefully. A lot less messy and it's reusable.
