Adapting a Steering Box
Discussion in 'The Garage' started by josh86k10, Oct 28, 2006.
  1. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    I think I've found a pretty good deal on a complete hydraulic assist setup from WTO. A guy bought it about a year and a half ago, set it on a shelf for a while and then sold his truck. He wants $280 shipped for everything (cylinder, lines, even the ported and rebuilt 2wd box never installed). Since my current 2wd box leaks like hell, I'd like to just bolt up this freshly rebuilt one...plus its already ported. But there's a problem....his box is the older flare style, my truck uses the newer o-ring style. What can I do to adapt over to the old style box as cheaply/easily as possible? Thanks in adavance.
  2. draggbody
    draggbody 1/2 ton status
    Jul 13, 2005
    282
    columbus GA
    cheapest thing would be use the old style pump and hoses... this away if you have a problem on the trail you dont have 'custom' parts to replace... any part store will have what you need...
  3. josh86k10
    Feb 13, 2005
    423
    Knoxville, TN
    Surely there is a cheaper way than buying two new lines and a new pump.... I hope. Is there a way to adapt my metric o-ring ends to a 3/8" flare (or whatever it is) with a short piece of 3/8" line or something?
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Change the fitting on the back of the pump and you're done. The return line is just a low pressure hose.
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    bingo, just swap the fitting on the box
  6. josh86k10
    Feb 13, 2005
    423
    Knoxville, TN
    Will the steering shaft connection be the same between the two boxes?
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    yes it should be the same.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Depends on what years the box's are. Worst case senerio is that you have to change the rag joint to the proper one which wouldn't be a bad idea anyway while you're messing with the steering.
