adapting TH400 to Ford 205
Discussion in 'The Garage' started by beater_k20, Dec 13, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    what are the tricks here? any 205s to avoid specifically? also, any way to run an electric speedo with this setup?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    All ford 205's are the same... Just swap out the 31 spline input with a 32.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you have to have the cases bored to put the 32 spline in there
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Also need an adaptor or redrill the t-case. The holes are close, but don't quite line up. MEK5 let me borrow his adaptor, it's bolted together, but haven't used it yet. Weekends are too far away.....least the front is done....
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    31 spline and 32 spline use the same bearing, so no boring to fit a 32 spline in a ford tcase.
    im not sure how far the pattern is off, but a np208 adapter (or gm round 205 adapter) then redrill the ford 205 case to fit the 208/205 adapter.
    unless you wanna spend $$$ on a AA adapter.
  6. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I did that to mine, just swapped inputs. I used a 208/241 adaptor. You could probly redrill the holes and be OK. As for the VSS, get the reluctor ring from the stealership, and the VSS sensor/pickup whatever yah call it from the junkyard, they are $100 new. Drill and tap the housing, need to clearance the inside for the reluctor ring to fit, IIRC hits oiling stuff.
  7. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    What are you going to do for a shifter?? The chevy adapter has the shifter boss on the PS and the Ford is on the DS.
