add-a-leaf or helper springs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCK5, Jan 18, 2003.
  1. SCK5
    SCK5 Newbie
    Jan 18, 2003
    So if there is one thing I don't know to much about, it's suspension. But I want to fix the rear suspension on my suburban. I do a lot of towing so I'm looking for something to help with the sag and add a little strength in the back, so that the hitch doesn't almost hit the ground whe I put something big on the back.
    I've looked in to add-a-leafs by rough country and Hellwig helper springs. But wich is better.
    Any ideas?
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I'ld go with the add a leaf for the reason, being added into the spring pack, it will lift up the natural stance of the rear whereas the helper springs go over the top and pretty much only come into play when loaded down.(Hopefully I'm talking about the right ones)
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Like the other guy said to help with your saggy ass a add-a-leaf is the only way I can think off right now ....well other than ORD's zero rate but that won't help with the towing I don't think.
    If it was mine I would and did get a full length Add-a-leaf it helped with the saggy ass.
    Eric
  4. BSav
    BSav Registered Member
    Nov 4, 2002
    41
    South East N.H. USA
    i would also go with the add a leaf over the helper springs.
    Also you may want to think about changing the shocks. I have Gabrial Air shocks in the back of my Blazer. I love them they will hold pressure up to 200 psi and as long as the fittings are all tight it will hold pressure for about 2 months. They lifted the back end of my truck so it looks real nice. I have also towed a 19 ft boat, and a big four place snowmobile tralier with four snowmobiles on it and the back end dosent drop much. It still rides nice with out weight in the back end, unlike the add a leafs may because they will be stiffing up the suspenstion. you can also use them in together for towing with no sag. The shocks cost me about 12-15$ a peice and the hose kit is about 8$ at your local pep boys, vip, or auto zone.
    Hope this helps, when you decide what you want and install post a follow up i would be intrested in what you choose and how you like it.
    Brian Sav
    88 GMC Jimmy, 350, stock height, and crome wheels for speed.
  5. dyeager535
    26,982
    191
    http://coloradok5.com/forums/showflat.php?Cat=&Board=blazer4x4&Number=444549&page=&view=&sb=&o=&vc=1
    An additional comment would be that I don't know much about how they work with a fair amount of weight on them. The difference in height between a full and empty gastank is not noticeable, and thats about 200lbs or so. I did it *solely* to fix the rear sag, and it ended up doing just that.
    http://yeagerd.home.mindspring.com/TablePics/rear33.jpg
    http://yeagerd.home.mindspring.com/TablePics/myK5.JPG
    Thats how bad the sag was BEFORE the add a leafs.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Beware that the rear shock mounts are not known for their strength. If you use them for weight bearing purposes, don't expect them to last long.
  7. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    tried the healper springs didnt do much except ride better under load
