Add a leaf question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Aug 1, 2000.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'm looking into buying some add a leafs for the front and rear of my rig. I only want about 1 to 1 1/2" out of them. So I know they will do nice. The question is, I was gonna order them from summit. They offer a short and long add a leaf. Whats the difference in the short and long one? Are there any advantages to either? Thanks for the help.
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    The short leaf will give a little more lift but they are stiffer than a normal spring leaf, they are also similar to an overload leaf in size and thickness.
    With the long leaf, you get a little less lift than the short leaf, but they are not as stiff.
    If I were you I would opt for the long leafs for a better ride.
    Also,If you see a lot of wheelin, add-a-leafs usually sag(at least the long ones)within in a year or two and you loose lift.
    HTH
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I put a set of the short leafs in the back of mine about 3 years ago. The ride really wasn't affected any at all. It did give close to 2" of lift though.
    Kyle
    89K5
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Sounds like what I need then, in a year or 2 I'll have a suspension lift under it. For now it's just give a little more clearence for the trail.
    89 K5 Silverado
