add a leaf questions
Discussion in 'The Garage' started by lunchbox, Jun 9, 2006.
  1. lunchbox
    lunchbox 1/2 ton status
    Jan 22, 2006
    309
    novato,california
    Ive been looking into purchaseing 2 inch add a leaf springs all around, all i want is to fit 33's. is this a good way to lift my 87 jimmy? would this hurt my steering? If anybody has any pictures of a blazer with a 2 inch lift and 33's could you show me? Any information on this topic would be great.
  2. dyeager535
    26,979
    Do you actually want to lift it, or just clear the tires? It can usually be done with no lift, but that all depends on the wheels and tires. If you really want the lift, then I'd say things like zero-rates or a shackle flip.
    Generally people seem to say the add a leafs hurt ride quality.
    That being said, I have stock 6 leaf rear springs, which were sagging heavily. (I measured somewhere around 2", go figure) I bought 2" add a leafs, and that brought the rear up about even with the front. I didn't notice a ride quality difference, but I won't say there can't be, or isn't, I just didn't notice, along with all the other harsh ride qualities.
  3. mrk5
    Apr 20, 2004
    12,335
    1,045
    Northern Colorado
    I didn't notice the ride so much, but they seemed noisy. Personally I'd be tempted to use zero-rates instead. Unless like Dorian mentioned, you think your springs are a little saggy.
    It shouldn't take much to clear 33s.
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I had a 'burb with 2 1/2" trailmaster add-a-leaves under it for a while. The springs were so worn out on that truck the add-a-leaves seemed to help the ride some.
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Here is my 74 with a 3" add a leaf in front and 33"x12.5x 15 [​IMG]
  6. lunchbox
    Jan 22, 2006
    309
    novato,california
    the springs arnt sagging at all, i just need the lift, but my main concern is losing the streetability of the truck if i go to 4 inches of lift.
  7. lunchbox
    Jan 22, 2006
    309
    novato,california
    i was just looking at off road desighn's 4 inch shackle flip kit what are the pros and cons of this type of lift? Is their alot of things i would have to change?( brake lines)
  8. dyeager535
    26,979
    I don't think there is much issue regarding streetability with 4" and 33's, some driveshaft issues which may add cost and time, but other than that, I can't see driveability being a concern with that small of a lift.
