Add a leaf w/blocks??
Discussion in 'The Garage' started by texas78k5, May 30, 2005.
  1. texas78k5
    texas78k5 Registered Member
    Apr 24, 2005
    26
    Kerens, TX
    I have a '78 k5 w/Rancho 2" lift....I want to use it to tow my trail toy. (a Nissan project)
    Anyway's, can I use an add aleaf with the 2" blocks in the rear?
  2. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Yes you can. Most kits have three ways of raising the rear. Say for a 6" lift.
    6"front/5" rear block
    6"front/add a leaf and block
    6"front/6" rear springs
    Thats how Super Lift and the others have there catolog set up.
  3. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i run a 4" block and ~2" add a leaf in the rear
  4. texas78k5
    Apr 24, 2005
    26
    Kerens, TX
    Thanks...was just wondering if there were any major issues to be concerned with towing/blocks/add a leafs.....
    Maybe it'll get rid of that saggy butt syndrome as well!
  5. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    thats exactly what it did, the only problem now is i have the shell off and its sitting a little high in the rear. now i need to install those 1" lift shackles i bought 6 months ago :rotfl:
    now when i put the shell back on, the front will be too high, and ill have to put the zero rates i bought in too... :D . good garage clean out, but then when i take the shell off again it will bug me... i guess its ok bc by the next time i need tires i will go through this cycle so many times ill upgrade from 35s to 38s :D
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Many trucks come from the factory with a block in the rear. And an add-a-leaf will help with towing as it gives a higher load capacity to your springs and will reduce spring wrap.
  7. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Both my Suburban and my Crew Cab have 4" rear blocks and 2" add-a-leaves. I've towed alot with both of them like that.
