Add a leaf with X over?
Discussion in 'OffRoad Design' started by stallion85, Aug 26, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I realize the issue with doing the 1" add a leaf with x over. I went out and placed the add a leaf between the spring and the draglink. There was about a 1/4" space in between the two. With that in mind would I have binding issues under flex or during steering. I guess I should turn the wheel and have someone look first. Damn it! I need to get my axle lifted to give my tie rod some clearance. It's rubbing on the bottom of the springs.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    It has a clearance issue either way I believe. Tie rod rubs or is very close with no 0-rate or with a zero rate the draglink rubs. Options are a steering arm spacer, dropped tie rod ends, modding the knuckles for bottom entry, or heims instead of tre's/dle's.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, what he said but we also have another twist, we have some 1/2" zero rates in stock. They don't have the offset feature built into them but it might be a good compromise in your case between the two clearances you're trying to juggle.
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Yea, my bud Dean told me he bought a set off you that were 1/2". I thought I just heard him wrong. I will probably order some soon, thanks Stephen. By the way saw you in 4wheeler tv Moab. Way to kick ass on that hot tub!!! Whose buggy was that with the awesome exhaust on it, man that thing sounded tough /forums/images/graemlins/peace.gif
  5. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,066
    190
    Colorado
    That would be me with the loud exhuast. Don't let it fool you. It's a stock 350 with loud exhaust.
  6. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I thought that rig looked like your avatar /forums/images/graemlins/thumb.gif Sounds awesome! What kind of exhaust do you have??
  7. miniwally
    Aug 11, 2003
    3,066
    190
    Colorado
    Dual 2.5 inch with some kind of cheap glasspack type muffler. It is really quite from idle to about 2000 rpm then it just gets loud.
