Add a leaf???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, May 1, 2002.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    Hey guys! I just installed a 4" procomp lift on my 88, it didn't really have to much of a sag in the back but the guy at 4wpw recommended I install a 1-1.5" add leaf in the back on top of the 4" block, it has 4" springs in the front... Now it looks like it's slightly jacked up in the back... has anybody else experienced this same thing before? Just want to know before I go out and remove the add a leaf... If I add a winch/bumper in the future it'll really look odd.. Whadya think?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you just installed the lift, then it will settle some, and over the years it will probably sag some too. So I would leave the addaleaf in that way down the road it will probably end up evening itself out.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I currently have 2.5" procomp springs in front,and 2 " block and add-a-leaves in the rear. It sits perfect. The add-a-leaf will lose some of it's arch,and make the ass end come down a bit. I would leave it in if I were you.
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i have the same thing, 4in lift, w/ add a leaf rear, it sat up a lot at first, but now 3 months late rit has settled and i dont notice that it sits higher in the rear, except when i took the top off, less weight in the rear.
    but if u do eventually add winch up front, then u can add leaves int he front, ord makes them and i know rough country does.
    also a procomp rear adda leaf is thicker than a rough country one so it lifts it more, but also makes it ride a lil rougher
  5. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    Thanks for all the advice, looks like I'll leave it in and use the time do other mods to the Blazer!!!
  6. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    Longer front shackles are an option also.
