add-a-leaf ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Russell Keys, Nov 20, 2000.
  1. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    I have a problem with the p-side sitting 1" lower than the d-side. Will add-a-leaves rearch both springs to the same, or will one still be lower?-Russell
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I think one side will still be lower.
    Check your frame, though. My front was off to one side and it wasn't the leaf pack, it was a bent framerail (eeek.)
    -- Mike
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Just have a fat chick drive your Blazer for a month straight! That should make all springs saggy.....
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Rearching might work, or maybe its time for a lift[​IMG]. My old springs sagged on one side, and I put a 1" block under them and it helped . ORD also makes some add-a-leafs that add one inch, but are for the "saggy butt" that most K5s have. Those might work if you just put it on the lower side.
    90K5
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Add a leafs are made to increase load carrying capicity.
    When your springs start sagging add a leafs are just a tempoary fix. And from my experience they make the ride harsher.If the springs are wore out, the bushings are too. It is far better to save up your money and get new springs and bushings. Your butt will thank you for it.
